Help, was cutting and went to empty hopper. Walked by the radiator and said that feels hot, it was at 190 degrees!
The electric fan wasn't coming on. Got home noticed when I turned key on the warning noise didn't come on, water temp light was out but oil light was on. I switched bulbs and same thing. Then I checked for voltage at the 1/4 degree
Switch on radiator nothing, then the bigger 3/8 degree switch and the fan came on when I grounded it with a test light! It cycled like it should ccw for a few seconds then switched cw and stayed running but no light or horn. Checked volts at horn had power going in but not coming out. When I grounded the wire going to 1/4 switch on rad. The water temp light came on but no horn. So I ordered a new 1/4 switch but still wonder if that will fix everything.
Hope someone can help. Thanks Brian
