Walker GHS Actuator motor
cabdor
I have a 2007 walker MTGHS mower I bought used. I took the actuator motor off to replace it ( locked up ) would not run. I checked with the manufacture the model number is for a 24 volt motor Could some one have replaced it with wrong motor? The electrical system is 12 volts on this mower. Does Walker use 24v motor to control speed of the actuator motor? I plan to buy a replacement. I need the right motor for my machine. Has anyone run into problem before? Thanks for any help you might have to clear this for me. cabdor
Walker
Model MTGHS
Serial 08-92432
Thanks Blzant for the info. I order the actuator motor they changed part number to 5519-9 works right now.
Info for other guys reading this. The motor is actually a windshield wiper for a boat. It's made by amequipment and the part number is the 212-2103. You can get one off of eBay for about 70 dollars. Some part numbers may vary but just remember that you want the housing to be the same shape as the one you removed from the machine, you need a 25mm shaft, 110 degree sweep and 12 volts. I removed one the other day that said it was a 24v so they must have been putting them in a lot of walkers.
