Walbro Throttle Plate Screw Sourcing
The Push mower
One of the two screws for the throttle plate is completely gone. Where might I find one? Engine Model 31P777. Thanks for any help.
EDIT: I believe I found it 691636. Red thread-lock for these?
Scrubcadet10
Moderator
Staff member
First i would attempt to find out where the missing screw is.... might be on it's way to your combustion chamber.
Briggs & Stratton 691636 appears to be correct, and it appears they already have a thread locker on them
The Push mower
The other screw is really loose. definitely going to dig around for it in the muffler and scope cam the cylinder.
The Push mower
Throttle shaft at the bottom is really sloppy and the top plastic bushing is well worn. Fix or replace?
Carb number is Walbro 697202
Steel binding head slotted screw 4-40 x 3/16. Less than 0.20 ea. including shipping. Use a little blue Loctite when installing.
