Walbro LMK carb problem
OhioBob33
Replaced float needle on LMK Walbro Carb. Still leaking and flooding engine.
Seat is not replaceable. Is there a way---or tool---to "dress" the input needle SEAT??
Any source for after market Carb replacement??
OhioBob33
Something that I have done from time to time is, on the larger seats put some valve lapping compound on the end of a Q tip and turn it several times while pressed down into the seat. On the seat with small needle valves, I have put the compound on the end of the old seat and done the same. Doesn't work all the time but may help.
Derson59
Try this site.
Walbro]Walbro
hope this helps. its off of walbro website. This will at least get you part numbers so you can order/find cheaper prices.
