Vintage Briggs & Stratton....Puzzled about model.
silver1
I have posted a number of times about my 6B-S motor.
I model/type/code/ with the type cutout of housing.
I'm wondering if housing has been swapped?
What is the bore and stroke of a 6B and an 8B?
LB
EngineMan
6B-S
Bore is 2.5/16"
Stroke is 1.1/2"
and gives 1.25HP at 2200 R.P.M
can't find manual on the 8B-LB but have a 8B-FB and that was....
Bore 2.3/8"
Stroke 1.3/4"
and gives 1.73HP at 2200 R.P.M
silver1
6B-S
Bore is 2.5/16"
Stroke is 1.1/2"
can't find manual on the 8B-FB but have a 8B-FB and that was....
Bore 2.3/8"
Stroke 1.3/4"
Thks Its 1.5 stroke 2. 5/16 bore...
silver1
  • / Vintage Briggs & Stratton....Puzzled about model.
Old is now new. Most parts places do not list model 6B-S. 060102 is a start.
The serial number of 661894 is higher than listed serial numbers for 1957/58.
I do not know what it was mounted to originally. It was green in color. I may
start it soon. Need to mount it on something.
LB
EngineMan
It looks very good with you, well done, the manual that I have list parts up to 901166, many will tell you that they didn't make them after the late 50's.
silver1
Is that (901166)the serial number or TYPE? I don't have the Type.
I haven't found one with the B/S stamp in the upper right corner, most are in the lower left corner.
EngineMan
That's type numbers.
