Have a Cub Cadet SLTX 1054. Put new blades on and noticed a vibration. Thought it was me but the vibration got worse and finally the belt came off. Noticed that the 2 of the ears had broken on one of the spindles. Pulled the deck off and ended up replacing 2 spindle assembly's. Put the deck back on and replaced the deck drive belt also. Started it up and still vibrates so I took the new blades off and sharpened the old blades and put them back on. Anyway still vibrating ?? Idler pully's look and feel good Getting aggravated so I've walked away from it. Any of you guys have any Idea's??
