Vibration on V-twin Briggs & Stratton Engine Only
Lionpaw
Good day Guys
I recently opened up much machine to change sump gasket and oil seal around the shaft.
On opening i noticed the governor was broken so i went ahead and replaced the same
I aligned the markings on the cam and crankshaft for the vale timing
Mounted back up and started easily
However there is now a significantly higher vibration on the engine. (no deck or blade hooked up) Engine only
Can anyone help me diagnose the problem??
Thanks
EngineMan
You may have a bad Counter Balance....but no one can tell you that unless you post up the engine numbers.
Lionpaw
Thanks EngineMan
Details of the engine are as follows AS BEST THAT I CAN GET:
Model: 407777
Type: 123-E1
Code: 990618YG
EngineMan
That engine does not have a Counter Balance, but it does have two cylinders so make sure both are firing, also check the all the valves, did you remark the governor (reset).
Catherine
LawnWorld Support
Staff member
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Briggs & Stratton section.
