why wont the valves stay adjusted on an 18.5 briggs
D daddy jim Forum Newbie Joined Jul 7, 2018 Threads 1 Messages 2 Aug 2, 2018 / valves #1 why wont the valves stay adjusted on an 18.5 briggs
I ILENGINE Lawn Royalty Joined May 6, 2010 Threads 43 Messages 10,732 Aug 2, 2018 / valves #2 Combination of camshaft lobe wear, push rod tip wear, rocker pivot wear and other things that change due to heating and cooling of the engine.
T Tinkerer200 Well-Known Member Joined Mar 14, 2015 Threads 4 Messages 913 Aug 2, 2018 / valves #3 daddy jim said: why wont the valves stay adjusted on an 18.5 briggs Click to expand... Long term, as above. Short term, rocker arm loose in head casting. Adusting mechanism not properly locked. Walt Conner
