Since buying my used '97 721D a few years ago, I have experimented with the various styles of blades.  It came with a set of mid-lift blades and I wasn't too impressed.  I tried low/contour and hi-lift blades and again... OK, but nothing to rave about.  This season I picked up a set of the fingered "gator" blades made by Oregon.  Man! these suckers are like twice as thick of the ones I had previously.  The cut quality is very, very nice.  I can cut full throttle, wide-open in even thick or wet grass and it snips them like a scalpel.  My only gripe is that the middle & discharge side blades were hitting each other.  They were the proper model/length, but every once in a while they'd hit and it was scary and noisy!  I ended up removing the right/discharge end blade and took about a millimeter off each end.  Once I had it oh-so-slightly shortened (and balanced) I re-installed and the occasional knocking disappeared.
I have a 72" deck.  Anyone else have similar troubles on their decks with this style blade?  I just found it odd that the recommended blades would do that?!?  It could cause a potential deck damage and/or someone getting very seriously hurt should one or more blades fracture or shatter while engaged!
