Universal Scalping Wheels
rdavis0627
Hi,
I'm still new here I have a LT1000 with a 38" deck, my yard is not the flattest in the land, I used to have a Murry 40" and I absolutely tore up the deck and blades, this mower I have now is in a lot better condition than the Murry ever was when I got it so I'd like to keep it that way. I've googled and searched here as well Amazon showed some, but I can't seem to find what I'm looking for as I'm not sure about angles on the decks and if they are the same or different. Can someone point me in the right direction as to how to go about getting some wheels for this deck and maybe some install tips for mounting them?
First you must find the brackets that can be welded on the deck since this deck was setup as a floating deck design. One set of these brackets is already NLA so that is of no help.
I would suggest looking in some of the local mower boneyards for ideas and brackets.
