Background: Mower was stored unused for 5-6 years.
Problem: Engine won't start unless I use starter fluid & it fires up and runs well. I can restart the engine w/o starter fluid once the engine is hot.
Repairs: Replaced fuel line, carb, primer board, ignition coil, spark plug. drained old fuel and replaced with new gasoline. Added Seafoam fuel stabilizer to help clean out fuel lines.
Does anyone have a suggestion to permanently correct this issue?
Thanks,
Doug
Thanks,
Doug
