Uneven cut
JLEBER777711
I have a 42" zero turn that is cutting unevenly. With all tires are at 15 lbs the blades measure 3 inches from the ground. The grass on the grass shoot side is higher. Thoughts??
Blade or two upside down? Seen it several times.
Wrong blades?
Wrong spindle?
