two toros
afoulk
Found these on CL. Thought they were pretty cool little mowers, and figure for $50, they are worth it, but wonder if I'd have any luck reselling them? How old do you guys think they are?
Pair of Toro 21" Aluminum Deck Push Mowers
If you post the unit model and serial numbers it is easy to answer your question. If those numbers are gone, post the model, type and code numbers for the engines.
