Chains & weights Two questions?
grroller
I recently purchased a used YS4500 Craftsman 21 hp riding mower. When placing it in the higher gear range the front end jumps up. What are the pros and cons of using wheel weights in the front and 35 lb. or 55 lb. ones recommended? Also, with less then 8,000 sq. ft. of lawn area and 5' beds around the house that are mulched is a dump cart worth buying as I do have a wheel barrow? At this point not experienced at backing up any accessories, thanks?
George
