i've got a black max with a honda GCV 160 something or other. i think its a model sams club used to sell 3-4 years ago. my uncle gave it to me. he says he hit something with it and it wouldn't run after that. he thought he sheared the key on the flywheel. i don't know about that. i brought it home, put gas in it and it fired right up but it wouldn't stay running unless i had the choke on. this afternoon i took the carb off and cleaned it. now it runs but it surges like the carburetor is dirty and its not getting enough fuel. the carburetor was clean when i had it apart. there are no adjustments on it. if i choke it it dies.
next i've got an old toro. it was in the dumpster at work. they said i could have it. i cleaned a bunch of crap out of the carburetor. i shot carb cleaner in everything. there were two brass screws, one with a spring, one without. i took them out and shot cleaner in the holes and put them back. the one without the spring was screwed in all the way. the one with the spring it took about 5 full turns to get it out, when i reinstalled it i turned it 5 full turns. it runs but it surges. if i choke it just a little it smooths out.
i don't know what else to do.
here's a samplin' of what they're doing.
