Turf tiger stumbles very briefly every once in a while
Jeeper
I have a 2005 turf tiger with the 29 dfi Kawasaki. I bought it last fall from a dealer. When I bought get it they had put one new coil pack on it and both plugs. I'm wondering if the other coil pack might be phasing out. Here's the symptoms.
The last two times I've used it it will stumble for a very brief moment. Maybe two seconds. It only does it when I hit a tall spot of grass or maybe turn in to an uphill while cutting. It seems to be related to putting the engine under a sudden load but doesn't always do it. It's done it twice while mowing each time. Other than that it runs great. It has 1,000 hours on it. It's as if it has a single cylinder miss for a brief moment. For now I'm going to keep using it until it gets worse. From experience with other equipment, intermittent problems can be hard to find until they get worse and then they show their face.
Any god ideas or people who've dealt with this already?
Thanks!
Just got done replacing all the coil on plugs for my 5.4L engine. If one goes out most likely the rest are not far behind.
