Turf Tiger Shutting Down
Peetee
I have a Scag 61" 29EFI Kawasaki 2010 mower.
I'm currently experiencing a problem with the mower wanting to shut down when I pull akc on the sticks or go into reverse. I previously had a similiar problem when the seat sensor broke out of the mounting brackets and I used a jumper that fixed the issue. This issue different. I have replaced the fuel filter, thinking it was a fuel issue. I havn't replaced the fuel pump yet. Could that be the problem or could it be in the hydraulics? As long as I am mowing in a stright line, I don't have a problem, it's only when I turn or back up does the mower want to shut off. It never completely shuts off, just drops the rpms to a very low level.
Any advise from anyone who may have had a similiar issue.
Peetee
I had a similar problem with my Tiger Cub. Turned out to be the relay near the ignition switch. Every time that I hit a bump or threw it into reverse, it would cut out.
