Hello everyone,
I need to remove my right side front caster wheel to work on my tire. Is there something more than removing the nut required to pull the bolt and the wheel assembly? If there is, it's not obvious (to me anyway ). If there's not, what's the trick for removing it?
Thanks in advance.
Thanks in advance.
