larryhughes
- Aug 19, 2012
- 2
- 4
Just entered the Scag mower world with a well used, and poorly maintained Turf Tiger. Still, it is running and all works, or will, when I get the seals for the gearbox and replace the bearings as well. When removing the left rear wheel I discovered washers under each lug nut. Someone had run the mower with loose lugs which wallowed out the holes. Need a new wheel. I did not see a forum for parts and accessories so need to inquire if anyone has a wheel for sale or can direct me to a source.
It is easy to see that this will be a valuable source of information as my Tiger needs just about everything.
