Tuffy Shift speed ground speed Question
cptmiker
Hello all I have a troy bilt Tuffy riding mower Model #13wv77kf066
My problem is the 7 speed shift. no mater what setting it stays the same speed. I have looked at the Diagrams on a few sites but none show any linkage for it. Is there a diagram or something i am missing. The shift lever moved a bracket mounted to the lower frame but i see nothing connected to it. Did I lose a part.
You didn’t lose anything. You have a variable speed unit which uses two belts and a stack style pulley with a moving center sheave. The sheave is stuck, not allowing speed changes.
cptmiker
Thank you for the info is the :Sheave part of the dubble pully in the backs-l500.jpg
Yes, that is the style I’m talking about.
