cruzenmike
- Feb 10, 2017
- 60
- 859
I have a John Deere LT155 that I am in the process of servicing. I know that the K51A transmission in the mower is not "serviceable" but I have seen many threads on the internet where owners have simply drained and replaced the fluid. I have done this same thing to the Hyrdo Gear 310-0510 in my Cub Cadet but I simply stuck with the recommended 20W50 conventional oil and did not see any significant changes in how the transmission felt or sounded. So here are a few questions that I have regarding the fluid change:
1) What is the best oil to put into the transmission? The manufacturer recommends and fills with 10W30 CD Class Oil.
2) Is there a way or is it even safe to try and spin the hydrostatic pump shaft while the transmission is mounted to the bench in order to purge the transmission and re-check the fluid level? I want to avoid having to put the hydrostatic back into the mower and taking it out again after it has been purged in order to top the oil off.
3) What is the best chemical to use to clean off the transmission to rid it of grease and belt debris without doing any harm to the seals or the aluminum casing?
I appreciate any help that you guys can give.
Mike
Mike
