Troy Snowblower 2410 Impeller making knocking sound
Elahiata
The Impeller of Troy 2410 snow blower was making knocking sound, I replace bearing and Impeller and still making knocking sound. I took Auger off and discount belt from pulley, the shaft the impeller on it and connected to bearing and
Polly can move up and down slightly by hand and it is not tight. Is suppose to be like this?
