Troy built cultivator
0303maz
I have a troy built cultivator edger. It starts fine but after thirty seconds it dies. Start back up fine and runs for thirty seconds and dies. Any idea what is happening. 4 cycle.
I would check for a blockage in the gas line or fuel filter. Fresh gas would help too. And if you have the time and ability clean the carb.
I have already changed the fuel lines and new gas. How do you clean the carberator. I noticed the prime pump bulb is cracked, could thid cause a problem?
