Troy bily mustang no crank
Zgray94
I got a 04 Troy bilt mustang zero turn 50 and. I’m not getting power to key switch I replaced key switch and soloniod battery has 12.5v I don’t get a click or anything when I turn key…BUT when I jump soloniod it will crank over gets spark and fuel but does not start?
Have you checked the fuses. Also could you post the model and serial number from the tag under the seat. Mustang is a generic model that can cover several variations.
Zgray94
Fuses are good I’ll have to get a picture in a few
Zgray94
MODEL NUMBER
17ARCACP011
521682
4-2004 Safety Standard
DOM
122013
SERIAL NUMBER
1L183H10200
Are you getting battery voltage at the B terminal on the key switch. If so can you hear/feel the fuel solenoid on the carb click when the key is turned on and off. Starting to sound like there maybe a either a parking brake or direction lever safety switch not working.
Zgray94
I am not getting power any where on key switch no clicking from anywhere either
