Troy Bilt Weed Eater
dwill85
Hello everyone, I have a troy bilt weed eater model number TB625 with a 4 stroke motor. It cut off on me and wouldn't start after about 20 minutes of use a few days ago. Gas tank was about half full, and the engine had oil in it. Since then it won't start and stay running. I can let it sit for a while and go back a little later and get it to start but it will only fire and run for about a half a second. Essentially it fires and cuts off. After that I can't even get it to fire like it is flooded. I just recently switched to a non ethanol fuel after using regular fuel with ethanol and a fuel stabilizer. I think this was the first time I had run it with the non ethanol. I have since tried to use the fuel with ethanol with a stabilizer but I still can't get it to run. I've cleaned the carb and it's passing fuel. All the lines seem to be passing fuel as the primer bulb is pulling fuel through the carb. Any ideas?
