Walk behind Troy Bilt Self propelled 6.75 hp.
jasbo
Mower usually starts on secod pull and runs for about 15 minutes and dies ,let it set for a hour and it started up again ran for few minutes and died again,ihave tried it a few times since then and it starts but dies after running about 15 min.what is wrong ,hope for a solution.
jasbo
After it dies, check to see if it has spark. I'll bet no, due to a failing coil.
kevlin
Did you ever find a solution to your problem? I have the same problem myself. Runs for 5 minutes then dies. Let it sit and try it again, same outcome, dead again in a few minutes. ..
Joel Baylor
Check your coil or just go ahead and replace it.
