Mechanic7471
- May 2, 2016
- 1
- 2
My rear bag on my Troy built 21" rear wheel drive 7.75 XP mower won't fill up properly and leaves long trails of grass on the lawn. Any ideas on why? Thanks!
Remove spark plug for safety, turn off fuel supply valve if applicable, carburetor side up & mower on its side, clean underside of deck & remove, clean & inspect blades for dressing up with a file or replacement if cracked or distorted. Use Troy Bilt OEM parts. Operators manual should have blade bolt torque.
