troy bilt pony
djtitleist1
I have a troy-bilt pony riding mower.Its about 6 or 7 years old. The problem that I am having is that it wont start. I turn the key and all it does is click click click under the seat. Sometimes I can come back days later and it starts fine. Now for the past week all it does is click. I have had the starter replaced and a new battery installed. Still does the same thing. Does anyone else know what I can do? HELP
BlazNT
Check your ground and what I mean by that is remove it from frame and take wire brush to frame mounting point and wire end the reassemble. Then if that does not work get a new starter relay after you test it by jumping both sides together to see if starter turns over when you do.
