I purchased a Troy Bilt Pony 17.5 HP riding mower from Lowes a April 2013. it has worked perfectly up until a week ago. it will not start! There is no click when turning the ignition, nothing. It is as if one of the safety switches is engaged and the electrical system is not working properly. Using a multitester I checked the battery 1st. It barely had a charge so I replaced it with a brand new battery and still the same issue. I called a Pony authorized dealer (per Lowes suggestion) and they thought its sounded like a blew a fuse. I checked the 20 amp fuse located under the battery with multitester and it appeared to be blown so I replaced it. Still didn't fix the problem. All wires and springs, etc... appear to be in good working condition. Any suggestions? And yes, I have made sure there is gas, the mower is not engaged, etc....
Thanks.
Thanks.
