Troy-bilt loose wire. Help?
ConnorE
Hi everyone, I have a Troy-bilt Pony and I need some help finding out where this wire goes. If any of you guys have the same mower I have I'd really appreciate if you could tell me where this plugs into. Mine is just sitting on the side under the carb. Thanks!!!
It looks like the power wires for the afterfire solenoid that may be on the bottom of the carb. Some engines have it some don't. If the engine runs without it then you probably don't have one. The wiring harness is universal from the OEM and then they use different engines with different features.
SONOFADOCKER
Wire harness is set up to run the caddy of Troy's do this plug is for an option you do not have .
