flyingsolo
- Jul 13, 2015
- 1
- 2
Ok I have two issues here with my Troy Bilt equipment. I have a Troy-Bilt 21" self propelled mower with a 190cc Briggs & Stratton engine. I was mowing the other day and it was running fine and then just died. I switched out the fuel and checked the oil. It was fine on oil, however it still isn't starting. I sprayed some carb cleaner in the air intake which usually gets it running, but it still won't turn over.
The other issue I am having is that my Troy Bilt TB80 EC weedwacker randomly stopped working a while back. I cleaned the carb and put it back together, however it still wouldn't start. New fuel was put in and it still wouldn't start. Did the same thing and sprayed carb cleaner into the air intake. On this one one it worked. The trimmer kicked on but wouldn't run smoothly. It would roughly run in the 2nd choke position but would die in the 3rd position. In position 2 whenever it would start to die and I sprayed carb cleaner towards the intake it would power back up and start running but it keeps wanting to die after about 15 seconds.
Anyone have any suggestions on what to try to see if I can get these going?
