Troy Bilt Help
The spring should connect in the small hole next to the square hole on the right side in this picture.
Most likely the hole were the spring was connected will have a keyway wear area and be shiny.
hollydolly
The back end is connected, I don't know where the end facing the camera goes. The belt broke so I think it is related to this spring.
