Troy Bilt Edger TB575SS Bog
Reinman
Engine bogs when I throttle. Replaced fuel lines, filter. Exhaust screen is very clean. Using ethanol free gas. Only thing I see short of replacing the carb is the gas tank doesn’t hold pressure well and looks like air is leaking between the gas tank and fuel lines. Looks like someone used some kind of silicon on it in the past, but I’m not sure what to use. Any ideas? Thank you very much.
