Troy bilt coil
PMcCarthy
I am searching for a TB coil that has been discontinued. I have searched everywhere, eBay, craigslist, all over the Internet. Part # 75304731. Backpack leaf blower is in excellent condition and really do not want to trash. Anyone know of a replacement? Any help would be appreciated. Thx
mechanic mark
Post complete model & serial numbers & year, part numbers are changing all the time.
BlazNT
Original part number is 9228-MD1802
Found one used on ebay
ebay.com/itm/Troybilt-TB25GHT-hedge-trimmer-ignition-module-coil-MC-9228-MD1802-/281921036644
I am looking for more. Model number makes this a lot easier.
BlazNT
In stock
lawnmowerpros.com/detail.asp?id=9228-MD1802
primerbulb120
Model number is TB25BP.
primerbulb120
Give Mowers4u a call at 315-753-0500 and see if they can help you out. :smile:
PMcCarthy
OK thanks for all the answers, I will follow up with them.
The model number is TB25BP and the s/n is 606B0305395
Thanks again!
PMcCarthy
No luck with the previous posts. "No longer available"
Just curious, a couple of the similar coils look identical, same mounting bolts, same curvature of the magneto. Only apparent difference is only one clip for wires, no doubt for the hot. All new models mount the ground to the block. The 75304731 has two leads a hot and a ground; for kill switch. Just wondering if I could attach similar coil and just ground the kill ground to the block???
primerbulb120
If you've got another coil, by all means try it. I wouldn't spend $15+ on a new coil just in hopes that it will fit.
Sellorelse
Did you ever find a new coil?
