Troy Bilt Bronco - access to second idler pulley.
Status
Not open for further replies.
Trout bum
I am trying to replace the two idler pullies on a Troy Bilt Bronco and am having an impossible time. It seems the nut to release the bolt is sandwiched between a top floor board and a lower metal plate. In other words for me to remove the pulley I need to drill a hole in the metal floor to get to the nut. Is there a better way that Inam not seeing. Thanks Jack
Scrubcadet10
Moderator
Staff member
Status
