I have a Troy Bilt 11A-436A711 that I can get to start. In looking at it, it appears to have a primer bulb that doesn't really do anything. It does not connect to the fuel tank, and looks to just push air into the carb. Has anyone else had a problem with this type of set up? Why is there a primer bulb that does not push fuel into the carb?
