Troubleshooting Slow Troy Bilt Bronco (2011) - FIXED!
dan2fs2ns
  • / Troubleshooting Slow Troy Bilt Bronco (2011) - FIXED!
Model: 13WX78KS, 2/2011
Only getting about 2.5mph out of the mower forwards/reverse. I've been lurking as this is a common problem but I think I've hit all the major points. New MTD upper/lower belts, and the routing is correct. The variable speed pulley seems to be working, but I'm starting to think maybe not all the way? When I apply pressure to the main drive belt the upper belt that drives the transmission does get wider, but I don't think it gets wide enough, maybe that center part isn't moving completely up/down? I found one youtube of a guy showing how his worked, and the belt almost seemed to ride around flush with the outside of the pulley, mine however only gets to about halfway.
I have also replaced the tension spring for the upper belt pulley with a new one.
My upper belt at rest, no gas:
My upper belt full throttle, pedal to floor:
Video of my pulley in action:
Video I'm comparing my pulley to:
dan2fs2ns
Here's a video of the variable speed pulley movement, seems clean/complete.
keakar
most common issue is the belt needs replacing, the belt sides are the only thing that wears so the belt can still look great but be worn out.
second most common issue is the small tranny tension spring to the frame rail gets rusty and weak, they only cost $10 to replace and to replace it, hook it to the pulley arm and run a heavy cord through the other end then use the cord to pull the spring through the hole to hook to the frame
dan2fs2ns
Thanks for the info! As mentioned in original post, I did replace belts with OEM and the tranny tension spring. I've since even sanded down pulley faces to reduce any glazing.
dan2fs2ns
Here's a video my brother took of his pulley, the upper belt is for sure getting moved out on that variable speed pulley much farther.
dan2fs2ns
You can also see on the top belt that goes to rear axle, the wear marks are not moving full out to the edge of the pulley.
Versus on my brothers, it's shiny to the edge:
Sounds like you need a new variable pulley then.
dan2fs2ns
Problem identified and solved!
The arm on the gas pedal bracket has apparently bent over time, so its throw was shortened and was not creating enough tension on the transmission belt.
In the image, new assembly is on the left, old on the right. The highlighted green line is where the arm should be...
Scrubcadet10
Moderator
Staff member
Wow! who'da thunk it!
I bet this will help someone in the future!
Nice find there dan2. Wonder how that arm got bent? Might need to keep an eye on it in the future? Probably some heavy footed drivers LOL.
