Trobilt riding mower starter
Gunner
I would like any info on how to change out a 12v starter on a B&G engine.
Thanks
Allen
depends on which briggs engine. some you can remove the cover over the starter drive and then remove the two bolts that hold it to the engine. others require that you remove the flywheel to get to the bolts. just make sure you hold the inner nut that the wire goes to so you don't twist the wiring inside.
Gunner
ILENGINE - thanks for the reply. I will check the wire and make sure I don't twist it.
Briana
Hey there - WELCOME to LMF! :smile:
I moved your thread to the Small Engine & Mower Repair Forum. You'll get a better response there. :thumbsup:
