My lawn boy 10734's height adjuster broke a couple weeks ago and I ordered a new one . Installed it today but after finishing the installion, I can't get the transmission to tilt anymore to produce tension on the belt. The cable is adjusted correctly because it stretches the spring out of resting position .
I have tried tilting the transmission with my hand with no luck. It's not being blocked by anything. I am dumbfounded to what I did because it was working before I changed the chute Assembly.
Any ideas? Thanks!
Any ideas? Thanks!
