transmission tank level
ACF
have a xt3200 dixie chopper does not want to pull correctly want to know what should be the level in the hydraulic tank and type of oil needed, and if you replace filters what is the amount of oil do you need
thanks
Auto Doc's
Look up Dixie Chopper.com for your machine service manual and fluid recommendations. There is no universal answer. You will need the model and serial number off your machine.
hlw49
Dixie Chopper uses Lucas 15W-40 oil level is just below the baffle in the tank.
hlw49
Holds about 1.5 gallons
