transmission parts
usm
Hello folks. new b here. Need HELP finding a thrush ball bearing for my peerless tranny motor/pump. I've looked at every site out there and even some ball bearing manufactures. All I have is a number i got off a washer that holds this bearing in place. Checking the net i find that other bearings come with this washer and they have a number on it. The info I get off the washer is china 1628X7 SST.. The size is: OD 2"--Bore Hole (as they call it) is 1 1/4" and thickness (width) is 3/16" and with the bearings in place it is 1/4". Hope you can help and also understand all this.
I do have a picture, but not sure how to attach it here.
Thanks everyone
If you want any hope here, you need to post the peerless/Tecumseh model/spec numbers, and we can look for your part that way.
the way you have laid it out, is assuming that some bearing guru knows what the hell you are describing and needing....
here u go fish. These r the #'s i have. As for Peerless this # is on the axle, 6892P91. Stamped on the pump is Tecumseh 6731-P1 (L)
