bobthewoodbutcher
- Aug 22, 2014
- 13
- 44
What fluid should I use to lubricate the chain case and differential case The manual says to add SNAPPER transmission grease
Is there a generic alternative that will work? I have some 90 weight oil from my outboard motor
I have not opened the plugs yet but based on the condition of the bearings they will not be full
thanks
thanks
