I used a silicone based sealer,...a high temperature gasket maker that I use on my exhaust headers on my cars, no leaks possible. I cleaned the entire transmission with a spray brake cleaner, then I wiped it all down with a clean rag, applied the silicone gasket maker,...which is good for 1200`F by the way, then put it all back together, tourqued the bolts to a guess, filled it with fluid, ran it through the paces for about an hour and a half, checked it, no leaks, no problems,.........so far,........I only use this tractor about 2 hours a week any way, I do my lawn with my Kioti CK20S HST. This littl tractor is for the fine trim work on my lawn.
I will let you know how I make out with it though. I believe there shouldn't be any problems, I figured if the 75W90 diff fluid can handle the abuse I put my manual transmission of my accent through, it can handle a 2 hour gentle ride on my tractor.
Trev:smile::laughing::biggrin:
