It's been a good mower for the small yard I have. I may could repair it if I had the parts but the housing has a good deal of wear where the input shaft enters the transaxle and would rather just plug and play.
Problem is cw rotation with axles in front of input shaft seems backward from most transaxles I have found.
The transaxle looks like it could have been made to rotate either way from the factory depending on the application because it has two input shaft locations side by side with one closed or unused, the metal tag says 915 032A PEERLESS 3083 1146
Its a 30 inch cut single blade riding mower. Anyone ever tried to replace this transaxle with any luck?
Thanks.
Thanks.
