transaxle filter-- Simplicity
ckain
I thought it would be good idea to replace rear axle oil and filter. I'm quite sure it never has been. However, now I cannot locate a correct filter.
Anyone here, have any experience with this issue. using Mfg part number comes up no longer available. Is an automobile automatic transmission filter ok to use(if it fits) ???
This mower is 1993, model 1692042- 16GTH. Anyone know what mfg made the trans unit ?
Thank you.
CKain
sgkent
[Briggs And Stratton Filter-Oil (194856-
Item Code: 1707873SM​
Replacement Part Description:
Briggs and Stratton FILTER-OIL (194856- Part Number: 1707873SM has been discontinued by Briggs & Stratton[/qupte]
from https://www.tufftorq.com/tuff-torq-corporation-csr/
6903f9d8f3ab6563576a2a3d7865a92b
Tom Hajek says:
I have a K215-A hydrostat on a simplicity mower, It has a 194856-86551 trans filter. Does anyone still have this filter? or is there a replacement?
433124e4084daedb286e49fac1e536b3
ggraham says:
Hello,
There is a replacement filter if you google this>> LFP8230 COMPANY FPC
https://www.filterspro.com/LFP8230-LUBER-FINER-OIL-FILTER_p_1664660.html
[/QUOTE]
So if it were me, following different discussions online about the part, documented above, I would take the old filter and the list from
According to the service manual the transaxle is a Tuff Torq K215A but Tuff Torq's Ordertree's IPL doesn't knowledge it.
The 1707873SM is a Tuff Torq 19485686551 (194856-86551) filter. The problem both are listed as NLA.
ckain
Thank You very much.
sgkent
Did anyone go to this link to see the 10 common replacements for that number someone else in another thread looking for one posted? Let us know if they match
Tom Hajek says:
ggraham says:
Hello,
