Transaxel changes by magic..??
Mike0627
I have an older Murray 309029x9. I had been having trouble getting the gears adjusted right but finally got it to run nice - but with three forward speeds plaus reverse. Ran great...
... then I let it sit for about two weeks I go to cut the grass and I have only forward gears... no Neutral and no reverse. WTH??!!?? I adjusted out the rod end that connects to the transaxle 15 turns before I got reverse. Didn't touch a thing in between these two times.
So What is up with that? Whats going wrong here? Any help would be appreciated!
TIA
Mike
