Howdy I'm in a bit of a bind at the moment, I have a bit of a older mower that has kept running for a little over a decade now and it's finally showing some serious wear and have to go about buying a replacement part. My issue is that the muffler has a crack in the pipe and needs obvious replacement. I have the model number for the mower but even after about 2 hours of "googleing" I can't seem to find one the looks like the old muffler. Any help would be greatly appreciated I'm a bit of a novice when it comes to this kind of thing. And it's a 1999, 12.5hp 38 inch Weed Eater Lawn Tractor, if you need pcitures of the mower or the muffler I can supply that as well.
