Towing capacity
BT2 Zeke
I have a RZT50. I was wondering if anyone has installed the optional "trailer hitch" on one then towed with it? I have a 50 gallon water tank that I need to move around two acres for watering the garden and trees. The tank is wheeled on both ends with a steering arm on the front wheels that makes it extremely towable. The property isn't flat. There are inclines that will add to the stress.
I'm just not sure about towing a potential 300lb. tank around with a 2007 RZT50.
TIA
BT2 Zeke
OK. Thanks guys you kind of confirmed my thoughts. I've already replaced one hydro. The other is getting replaced this winter.
