The bolt that engages tow mode on one side is way too tight, had to use breaker bar to loosen and now concerned I will break something to get it back to mow mode...any advice would be helpful, Thanks !!
IF this is the 942211 which has HG PL BGQV DY1X-XXXX pumps. You should replace the end cap and the bypass valve. Of you re-use the check valves and don't mix them up either.
The main problem is the end cap costs $431 retail.
