torro12-38 xl stalls out
whall
Hello &help
I have a toro 12-38 XL will run at lower speed but when speeding up or engaging the deck stalls out, seems to flood out.
ran it with the air cleaner off and could see the gas splash out have cleaned the carb and new gas.
The tractor has a new batt and replaced the solenoid (used a spare from a car i had here and only used the white wire from ignition switch ,left the black and white from the safety relay off)
My guess (and thats what it is) is ignition breakin down or a valve sticking . any thoughts?
thanks wayne
